Importance sampling
freitag
Importance sampling
Post by freitag »
I already asked a similar question before, but maybe in the wrong context. I couldn't find any documentation on the importance sampling neither on the web nor in your thesis. The way I used the importance sampling was by adding a new run, setting RunType to 'Importance sampling' and then start it as a joint run with the previous 'Optimization' run. Then I assumed that the models created from this run sample the approximate PPD of the previous run, as described in Sambridge1999b. Thus I should be able to calculate bayesian Integrals from the ensemble parameters of the 'Importance sampling' run. Are these assumptions right?
Cheers,
Yannik
Hi Yannik,
The importance sampling option in graphical user interface is now removed. At that time it was rather experimental. Now, you'd better use one of the latest release (>=2.1.0, will be available soon) and only through command line interface: http://www.geopsy.org/wiki/index.php/Im ... e_sampling
