Selecting the 200 best models through command line
Postby admin » Tue Jan 15, 2008 6:28 pm
There are two options you can use to extract models from .report file: -n and -m.
gpdcreport run_01.report -pm -n 200 -m 0.7
It reads the .report sequentially. When it encounter a model with a misfit less than 0.7, it is output. When 200 models have been output, it stops. There may have more model with low misfit afterwards. They are ignored. Even, the best misfit may not be output.
To solve this issue, you have to sort and select yourself the models with option -i. The first step is to get the list of the very best models
 2547     4    414.864    1191.89    1243.14    2779.02   0.620958
 2548     4     414.13    1194.27    1244.61    2780.87   0.620442
 2549     4    414.199    1193.72    1244.14    2781.21   0.621037
First column is the model index, second if the number of parameters for each model, follow the value for each parameter (4 columns) and finally the misfit value. What we need is the first and the last column. We use awk to get them:
gpdcreport run_01.report -pm | awk '{nd=$2;print $(3+nd) " " $1}'
0.620958 2547
0.620442 2548
0.621037 2549
Then we sort by increasing misfit and we select only the first 200:
gpdcreport run_01.report -pm | awk '{nd=$2;print $(3+nd) " " $1}' | sort -n -k 1 | head -n 200
0.680778 2171
0.680782 2320
0.680819 2334
We extract only the indexes needed by gpdcreport to reference the models to output:
gpdcreport run_01.report -pm | awk '{nd=$2;print $(3+nd) " " $1}' | sort -n -k 1 | head -n 200 | awk '{print $2}'
2171
2320
22334
Finally select the type of output you want (-pm...):
gpdcreport run_01.report -pm | awk '{nd=$2;print $(3+nd) " " $1}' | sort -n -k 1 | head -n 200 | awk '{print $2}' | gpdcreport run_01.report -pm -i
 2171     4    443.078       1068     1154.3    2739.32   0.680778
 2320     4    444.308    1066.81    1157.04    2740.98   0.680782
 2334     4    443.908    1069.52    1159.58    2743.61   0.680819
You can also re-export to a new or an other existing report with option -report. The last operation is not working with current release. It will be available in next release (> 20080115).
smolnar
Re: Selecting best models
Postby smolnar » Wed Aug 06, 2008 12:50 am
And then what? Dinver does not "open" report files.
Put the re-organized *.report file in ./dinvertemp folder and plot the profiles using Dinver?
mao
Selecting best models ... continued
Postby mao » Wed Aug 13, 2008 6:56 pm
you can simply pipe the output into figue for plotting if you like -
or once you have created a new report containing the best nnn models
you can also use gpdcreport and pipe the output to figue for plotting
bye
Matthias
mao
short extension for multiple report scanning
Postby mao » Sat Sep 06, 2008 6:53 am
for whom it concerns:
if scanning the minimum misfit models from several reports you need to
avoid some additional header lines - I used:
gpdcreport run*report -pm |\
awk '$1!="#" {nd=$2;print $(3+nd) " " $1}' |\
sort -n -k 1 | head -200
so the only difference is to suppress those lines starting with a "#"
bye
Matthias
Return to “Dinver usage”
Users browsing this forum: No registered users and 0 guests
