max2curve k-limit filtering
mao
Post by mao »
I tried today the Filter button on the bottom of max2curve tool.
It behaves as expected at first glance - it removes the histogram outside the
specified k-bounds. Later I learned that this filtering is not permanent - it
seems not possible to apply gird statistics on the filtered map... the full histogram
appears again. Similar the save button saves the full information as in the original
max file... I hoped, I can remove effectively a lot from the grids and then paste them
together...( I am using sesarray-2.0.3)
Another suggestion maybe too dangerous to be abused, but it could be nice
to have a slider for kmin and kmax to adjust the lines for cutting visually and then
pass the values to the filter.
bye
Matthias
Hi Matthias,
I'm not sure but as far as I remember, the saved .max file is not exactly the same as the original. There's an additional column with 0 or 1. Can you confirm?
Yes a slider could be a nice option. I add it on the stack of TODO
mao
Post by mao »
thanks - yes finally I noticed that there was an additional column with
either 0 or 1 - thanks for the reply - I couldn't remember that I put it here on
the forum.
tbye
Matthias
