Altering the curves in a .page with bash
Postby admin » Wed Jan 30, 2008 5:56 pm
We assume that a file dc.page exits and contains plots of dispersion curves , slowness versus frequency. We want to transform them into wavelength versus slowness. Additionally, we would like to smooth these curves in a "clever" way which keep the up-down traveltimes constant.
We first extract the content.xml file contained in the .page file:
tar xvfpz dc.page
The content.xml file is an xml file encoded in UTF16 (unicode). With 'cat', 'awk',... unicode may not be considered properly. First we convert it to basic ascii encoding:
iconv -f UTF16 -t ASCII contents.xml > contents-ascii.xml
All dispersion curves can be extracted from the xml content:
cat contents-ascii.xml | awk '/[0-9\.]+ +[0-9\.]+ +[0-9\.]+/{print $0}'
The next step is to modify these parts of the xml content without touching the rest. We replace the [frequency,slowness] by [slowness, 1/(frequency*slowness)=wavelength].
cat contents-ascii.xml | awk '/[0-9\.]+ +[0-9\.]+ +[0-9\.]+/{print $2 " " 1/($1*$2)}!/[0-9\.]+ +[0-9\.]+ +[0-9\.]+/{print $0}' > contents.xml
We re-direct everything to content.xml to build a new .page file. If the original dc.page contains other files (usually starting by bin_...) you must pack them as well in the new file. Skip 'bin_data_100*' if your original dc.page file contains no binary file.
tar cvfpz dc-wavelength.page bin_data_100* contents.xml
The created file can opened in figue:
figue dc-wavelength.page
You may be a bit disappointed because all plots are probably blank. This is just a problem of axis limits. Change the axis properties as you want, make use of mkup files to propagate them if you have various plots. Save your changes to dc-wavelength.page.
Secondly, we can calculate the smoothed slowness curves keeping the traveltimes constant. We start from the last dc-wavelength.page.
We first extract the content.xml file contained in the .page file and convert it:
tar xvfpz dc-wavelength.page
We revert the sort of curves obtained so far to get increasing wavelengths:
cat contents-ascii.xml | awk 'BEGIN{n=0}/[0-9\.]+ +[0-9\.]+ +[0-9\.]+/{x[n]=$0;n++}!/[0-9\.]+ +[0-9\.]+ +[0-9\.]+/{if (n>0){for(i=n-1;i>=0;i--)print x[i];n=0};print $0}' > tmp
We compute the smoothing itself:
cat tmp | awk 'BEGIN{l=0;s=0}/[0-9\.]+ +[0-9\.]+ +[0-9\.]+/{nl=$2;s+=$1*(nl-l);l=nl;print s/l " " $2}!/[0-9\.]+ +[0-9\.]+ +[0-9\.]+/{s=0;l=0;print $0}' > contents.xml
The contents.xml can be converted to .page file the same way as shown above.
bre
Converting page file from frequeny/slowness to wavelength
Postby bre » Thu Feb 07, 2008 12:59 pm
I just tried to follow your instructions about converting the dispersion curves from the page file (for our brandnew NERIES data), but when I type the third line
my computer responds:
/[0: Event not found.
As I'm not so familiar with regular expressions (at least not with such complicated ones), I do not know what it does not like about the !/ stuff... Any idea? Should this work for all shells or just in bash? (Already tried both bash and csh, no difference in response).
Brigitte
bre
Solution found
Postby bre » Fri Feb 08, 2008 12:16 pm
Just found out what was the difficulty - in my bash, I need to add a space behind the "!" so the regular expression is interpreted correctly. :)
Brigitte
Return to “Miscellaneous”
