stratigrafic parameters
riccardo
Postby riccardo » Tue May 16, 2017 4:05 pm
good evening Mark
is it possible to extract the ' stratigrafic' parameters in a txt file from *.report?
thanks
Re: stratigrafic parameters
Postby admin » Mon May 29, 2017 9:17 am
Hi Riccardo,
What do you mean exactly by 'stratigraphic' parameters?
If you want to extract the Vs profiles:
gpdcreport your*.report | gprofile -vs > your.txt
riccardo
Postby riccardo » Mon May 29, 2017 9:35 am
Hi mark
for stratigrafic parameter I mean the data of *.param file.
the data of generic model that geopsy use.
VP, VS, ni (poisson) , gamma, thiknes
Postby admin » Mon May 29, 2017 10:17 am
If you run
gpdcreport your*.report -pm
You get one model per line with as many columns as the number of parameters in the .param file.
Exact format:
model index
number of parameters (even the fixed ones)
param1
param2
paramN
misfit
Return to “Dinver usage”
