batch processing - geopsy-2.1.0
mao
Postby mao » Wed Jan 28, 2009 9:16 pm
I just noticed that something apparently changed in the last
version for the batch processing - I try to run the same (let's better
say a similar) script for batch processing as I did last November using
version 2.0.3 (I think) - now I get:
----WARNING--- Loading signal ...----
Unknown format for ost-00-batch-fk-28012009.log
geopsy: no signal available, check options -file, -db or -group, see -h for help
I think the error message startgin from "geopsy:" is not indicative - what
might have change in the code is some different or stricter
checking of the parameter file? I attach the parameter file below
hmm can't upload the file :-| apparently you secured the upload in the forum
- well let me know if you need the file for analysis
read u
Matthias
Postby admin » Thu Jan 29, 2009 4:27 pm
Hi Matthias,
Can you post the complete command line you started? Option '-file' is now obsolete. Replacing this option by direct file specification is quite useful when you have several files to open.
mao
command line....
Postby mao » Thu Jan 29, 2009 4:38 pm
geopsy -db /home/mao/DATAPROC/LUENEBURG/lg20070904.gpy -tool geopsyarray -slot 0 -group ost-2007090400-z -param ost-00-batch-fk-28012009.log
here I copy&paste the param file:
### Parameters ###
WINDOW MIN LENGTH (s) = 80
WINDOW MAX LENGTH (s) = 80
WINDOW LENGTH TYPE (at least/exactly/freq. dep.) = freq. dep.
DO BAD SAMPLE TOLERANCE (y/n) = n
BAD SAMPLE TOLERANCE (s) = 0
DO WINDOW OVERLAP (y/n) = y
WINDOW OVERLAP (%) = 50
DO BAD SAMPLE THRESHOLD (y/n) = n
BAD SAMPLE THRESHOLD (%) = 99
ANTI-TRIGGERING ON RAW SIGNAL (y/n) = n
USED RAW COMPONENTS = y, n, y, y, y, y, y, y, y, y
RAW STA (s) = 1
RAW LTA (s) = 30
RAW MIN SLTA = 0.3
RAW MAX SLTA = 2
MINIMUM FREQUENCY = 0.5
MAXIMUM FREQUENCY = 25
INVERSED FREQUENCY = n
SAMPLES NUMBER FREQUENCY = 100
SAMPLING TYPE FREQUENCY (0=log, 1=linear)= 0
FROM TIME TYPE = 0
TO TIME TYPE = 0
FREQ BAND WIDTH = 0.03
N MAXIMA = 3
MIN V = 100
FROM TIME TEXT = 00:00:00.000
TO TIME TEXT = 01:00:00.000
MIN K = 0.0053
MAX K = 0.9
OUTPUT FILE = /ldat4/LUENEBURG/ost-00-batch-fk-28012009.max
### End Parameters ###
thanks for checking
Postby admin » Thu Jan 29, 2009 4:44 pm
Sorry, I remember I encountered this problem when I removed the option '-file'. This is in the list of things to correct asap. I recently moved to git for version control (abandoning the old cvs) and things are still not working correctly for generating new snapshots. I hope to fix all scripts again asap to be able to fix this problem.
If you have an urgent need, try with release 2.0.5.
mao
ok!
Postby mao » Thu Jan 29, 2009 5:30 pm
ok - all fine - I'll go back to an earlier version - I should still have 2.0.3 or so somewhere...
an ls in /usr/local gives me:
/usr/local/sesarray
/usr/local/sesarray-2.0.0-snapshot-200701005
/usr/local/sesarray-2.0.0-snapshot-20070801
/usr/local/sesarray-2.0.0-snapshot-20070810
/usr/local/sesarray-2.0.0-snapshot-20071114
/usr/local/sesarray-2.0.0-snapshot-20071119
/usr/local/sesarray-2.0.0-snapshot-20071206
/usr/local/sesarray-2.0.0-snapshot-20080118
/usr/local/sesarray-2.0.0-snapshot-20080306
/usr/local/sesarray-2.0.0-snapshot-20080517
/usr/local/sesarray-2.0.3
/usr/local/sesarray-2.1.0-snapshot-20081206
I feel like a hunter :-) have a nice evening
bye
Return to “Geopsy usage”
