Geopsy MASW changing sources BUG
EduardoPitta
Postby EduardoPitta » Thu Oct 10, 2019 7:19 pm
I've been working with MASW and I came across a really annoying bug.
I can't change the source of a shot with the new version, while in the other I can do that normally. I believe this is a bug.
Re: Geopsy MASW changing sources BUG
Postby admin » Thu Dec 05, 2019 9:07 am
Source positions are effectively no longer available with the signal properties in a table. Instead, sources are defined in a separate table ("Events"), right click in the tool bar if it does not appear. By default it is at the same level as "Files" and "Groups" tabs.
Right click on the event table to add new events. Set the correct absolute time and position. Normally, when loading a SEG2 file, a source is automatically added. Are you using other formats?
Return to “Geopsy usage”
