Problem for installation of sesarray
tahoser
Post by tahoser »
Hello Mr Marc,
With this configuration of my computer and the package installed:
qmake -version
Qmake version: 1.07a (Qt 3.3.8b)
Qmake is free software from Trolltech ASA.
lupdate -version
lupdate version 3.3.8b
uname -a
Linux lgit-d109 2.6.27.19-170.2.35.fc10.i686 #1 SMP Mon Feb 23 13:21:22 EST 2009 i686 i686 i386 GNU/Linux
When I tried to install sesarray, I had the following message:
./configure
*** ERROR *** : qmake command is not available.
Either Qt is not correctly installed
or PATH does not point to Qt binaries.
I do not know where is the problem. I am new with linux so I am not sure where and how to fix the problem.
Thank you very much.
First of all you have to install version 4 of Qt. If it is not available directly in your distribution package manager or if you have no root permissions, you have to compile Qt 4 from scratch.
Once Qt 4 (minimum version is Qt 4.3.3, but 4.4.3 recomanded) is installed (usually into /usr/local/Trolltech but it might have changed to /usr/local/QtSoftware), add the path to Qt tools in your PATH environment.
export PATH=/usr/localTrolltech/Qt-4.4.3/bin:$PATH
Now you should have a qmake -version like this:
QMake version 2.01a
Using Qt version 4.4.3 in /usr/local/Trolltech/ppc-10.5/lib
If have access to LGIT network, you can use the release installed on 'risques' server (in /usr/contrib/bin if your environment is not standard).
